TwinTurbo.NET: Nissan 300ZX forum - A bad alty can cause this issue to - easiest way to find
Subject A bad alty can cause this issue to - easiest way to find
Posted by jzack on January 29, 2011 at 11:04 AM
  This message has been viewed 149 times.
In Reply To over night battery uncharged posted by Serg300zx on January 28, 2011 at 08:15 PM
Message is to put an amp meter in series with battery's negative terminal and measure current flow. You'll likely find 0.5 amps or more -- measure with all cars doors closed, security light on dash off, key off, etc.
Next start unplugging fusible links (box in front of battery) and note which pulled link causes the amp meter to read 0 current. That will help you track down which car circuit is causing this issue...
